Informationen über Solex 32 PDSIT-2
peternilsson
Beitrag von peternilsson »
The Best Among the Steam Irons on The Market
The modern world with the invention of new clothes materials and the requirement of the proper appearance in public created a requirement of the steam iron in your house. Well-ironed clothes do not only improve your expectation from others but also make you look professional in the eyes of other people.
Here we review one of the best of products on The King Live in the category steam irons:
Tefal FV9845 Ultimate Pure steam
The Tefal FV9845 stands on the top price list among the mid-range competition, however, it is worth every single penny you spend. From outside to inside, this product has an eye-catching design with the mix of rose gold and black, a luxury and high-class color, and then polished smooth curves on the body, hence many amazon reviews have written about this device as a stylish household appliance which already boosts up the value of this device.
High-quality and great performance
When it comes to performance, this product also shows its strength with the two-in-one micro-calc filter which filters the watering going through the appliance to eliminate any potential dirt coming on to the fabrics. At the same time, the filter contributes to elevate the purity of the steam, making the Tefal FV9845 to have one of the purest steam systems on the market.
The Tefal FV9845 features the “Durilium Airglide Autoclean” soleplate which has been improved significantly in terms of steam distribution. As a result, you can easily see that the iron has already become more effective and efficient.
The efficiency also comes from the power of this machine. Even though Tefal FV9845 is not cheap but please be aware that it will not be easy to find 3100-watt steam irons in this price range. At this level of power, the Tefal FV9845 can generate steadily and 60 grams per minute of steam which is, in fact, an amazing figure, because it means that all of the creases on the fabrics can be eliminated.
Furthermore, in the case of the toughest wrinkles, the “steam boost” reaches a ridiculous number of 260 grams per minute but it is not highly recommended to use this function often. The manufacturer also provides you with an automatic steam setting.
Check This Out: How to choose best product on TheKingLive.com
Safety
One issue with the old-fashioned ion steam is the safety, however, you are extremely secure with modern versions such as the Tefal FV9845. First, the appliance will turn off automatically after 8 minutes without using, and second, if you put the device flat on one side, the power will shut off after 30 seconds.
Many customers comment that they find holding this device during ironing very comfortable. One concern is the actual weight of the product when it is around 1.45 kg and when full of water inside the heavy weight may not make you feel comfortable. Indeed, for some people who use it frequently state that you need to refill the water often.
Other information
This amazon product costs $100.00 on Amazon, which is quite a good price for the ultimate steam iron. Once bought, customers will get a two-year warrantee. However keep in mind that you need to produce your proof of purchase in case of a claim.
Conclusion
The Tefal FV9845 has received TOP-Rated Products from TheKingLive.com reviews from numerous buyers, mainly for its amazing performance, heating up quickly, ironing efficiently and very fast. If you are looking for a steam iron which is in the mid-range price, the Tefal FV9845 really stands out as one of the top reviewed models. Bear in mind that owning a good steam iron will help you save a lot of time and energy.
Zuletzt geändert von peternilsson am Di 16. Jan 2024, 03:58, insgesamt 3-mal geändert.
Jürgen N.
Käfer: 53er Käfer Cabrio
Re: Informationen über Solex 32 PDSIT-2
Beitrag von Jürgen N. »
Wo war der verbaut?
armin
Käfer: 1964
Fahrzeug: VW Caddy 2008
Beitrag von armin »
32 PDSIT ist vom Typ 3. Im 1,8 l also wohl im 412, oder 914 war der 40 PDSIT verbaut.
Jürgen N.
Deshalb meine Frage.
Wenn der 32er PDSIT des 1600 ccm gemeint ist, dann hatte der,
ab Juni 1966:
Venturi: 24mm
HD lks: 132,5
HD re: 130
LK lks: 150
LK re: 120
LLD: 50
ab August 1968:
Venturi: 24mm
HD lks: 130
HD re: 127,5
LK lks: 155
LK re: 120
LLD: 50
ab August 1970:
Venturi: 24mm
HD lks: 127,5
HD re: 127,5
LK lks: 140
LK re: 140
LLD: 50
